AndrewSopher Posted September 11, 2023 Share Posted September 11, 2023 I thought Chief had fixed the brick ledge/exterior wall material extensions/depth in x15. I cannot get them to work if they are in a pony wall. Example: I have real stone wainscoting with stucco above (pony wall) and a standard 9' foundation below and I want my brick ledge depth to be 24'' (where I want the grade to be). Is this a bug or not? Link to comment Share on other sites More sharing options...
AndrewSopher Posted September 11, 2023 Author Share Posted September 11, 2023 41 minutes ago, solver said: How about a simple plan -- just 4 walls, showing the problem. Here is what I see using the default wall types. Thank you. Must be something on my end. Appreciate the response. Link to comment Share on other sites More sharing options...
