Roof issues
nsheppard
Go to solution Solved by BruceKC,
  • Solution
On the left side check the plate height or fascia height and make sure it's the same as the roof planes facing you.  Lock the roof pitch and then change the fascia height and then rejoin the roof planes.  I think that should work.
