Digger873 Posted April 25, 2023 Share Posted April 25, 2023 Anybody seen these problems before? It doesnt end with the problems in the pictures either, If I do floor trusses it, creates a 3/4 x 3.5 inch osb truss and a floor truss, when I use automatic. When I manually draw a floor truss it only does the 3/4 osb and nothing else. Some foundation walls it only draws a sill plate across half of it, with no rhyme or reason that I can find not to draw the whole thing. Thanks in advance Tina's and Kelvin's Residence-Rev 2 picture.pdfFetching info... Tina's and Kelvin's Residence-Rev 2picture2.pdfFetching info... Tina's and Kelvin's Residence-Rev 2 picture3.pdfFetching info... Link to comment Share on other sites More sharing options...
mLongChief Posted April 25, 2023 Share Posted April 25, 2023 Hard to say exactly what the issue is without a plan. I'm assuming the issue in the images is the white wall framing members. My best guess is a layer in your walls is marked to be a framing layer when it shouldn't be. That Framing checkbox indicates whether or not the program will attempt to build actual framing within that layer. That checkbox for wall layers can be found within the Wall Type, on a per layer basis within that wall type. The floor trusses is probably a similar issue, that your OSB floor layer checked to be a framing layer within your floor structure. Unchecking that for the OSB layer should prevent the trusses building within it. 1 Link to comment Share on other sites More sharing options...
Digger873 Posted April 25, 2023 Author Share Posted April 25, 2023 With help from support, it was easy, turns out in the walltypes box you can turn on framing and whatever material is highlighted will act like framing members. Thanks Link to comment Share on other sites More sharing options...
