V-Groove Arched Panel Doors
keilrd
I recently had to put these doors back together and tried to improve the geometry some. There will still be a couple stray lines that need cleaned up in the layout, but otherwise, they seem to work fine; materials are separated inside and out, and vertical from horizontal grain. The other issue with the geometry is only that the door panels are slightly thicker (1.41) than the 1.375 rails and stiles, so you may want to adjust the 2d block; there is a 32" thin panel version included as well, which is probably more authentic than the the thicker panel versions (which show the grooves better), and which have been included in 30, 32 and 36" (I will come back here and upload if I end up having to make a 24 or 18 wide one.)
Hopefully they will be useful to someone else.
V-Groove Arched Door.zip
