Window Apron Option Missing
DougDM
Am I imagining we have an option to select Window Aprons from library & returns Pre X15?  I know we can check to have or not to have but I'm pretty sure we had control over the profile of apron. Attached is a Niche where I have no option to selected the apron to match casing.  Even the actual window aprons don't match the casing. Nor can I change it,  I could swear we used to be able to. Or was I doing it manually with 3d moldings and I'm losing it. :) Hummmm
Your best option for getting the look you want is probably turning off the apron and adding a 3D Molding Polyline.
Sort of, but it was a bug introduced in X11 and fixed in X15.
In X11-X14 the apron would use the molding profile of the sill. This is rarely what you would actually want, so we reverted it to the old behavior. Neither behavior would have let the apron match the casing profile. See the attached plan.
X10                                                              X11
image.thumb.png.77ba016ffb0e2d3ac175ac587e2555ef.png   image.thumb.png.75cc612a35878e265ad1105dd97114f2.png
SillAndApron.plan
22 hours ago, JacobB said:
Your best option for getting the look you want is probably turning off the apron and adding a 3D Molding Polyline.     Exactly what I did
X10                                                              X11
