DougDM Posted April 17, 2023 Share Posted April 17, 2023 Am I imagining we have an option to select Window Aprons from library & returns Pre X15? I know we can check to have or not to have but I'm pretty sure we had control over the profile of apron. Attached is a Niche where I have no option to selected the apron to match casing. Even the actual window aprons don't match the casing. Nor can I change it, I could swear we used to be able to. Or was I doing it manually with 3d moldings and I'm losing it. Hummmm Link to comment Share on other sites More sharing options...
JacobB Posted April 17, 2023 Share Posted April 17, 2023 Your best option for getting the look you want is probably turning off the apron and adding a 3D Molding Polyline. 31 minutes ago, DougDM said: I'm pretty sure we had control over the profile of apron. Sort of, but it was a bug introduced in X11 and fixed in X15. In X11-X14 the apron would use the molding profile of the sill. This is rarely what you would actually want, so we reverted it to the old behavior. Neither behavior would have let the apron match the casing profile. See the attached plan. X10 X11 SillAndApron.plan Link to comment Share on other sites More sharing options...
DougDM Posted April 18, 2023 Author Share Posted April 18, 2023 22 hours ago, JacobB said: Your best option for getting the look you want is probably turning off the apron and adding a 3D Molding Polyline. Exactly what I did Sort of, but it was a bug introduced in X11 and fixed in X15. In X11-X14 the apron would use the molding profile of the sill. This is rarely what you would actually want, so we reverted it to the old behavior. Neither behavior would have let the apron match the casing profile. See the attached plan. X10 X11 SillAndApron.plan 2.72 MB · 0 downloads Link to comment Share on other sites More sharing options...
