Bookshelf Girts in Post Frame Building
Design20
Is there a way to automatically generate bookshelf girts spaced 2' O.C. between posts in a post framed wall in Chief?  (Idk if there's a different term for them, but around here we call flat girts btwn posts "bookshelf girts," and it is the typical way to frame a post frame building.)  Currently the closest I can get is to check the Exterior box under Build Framing dbx>Wall>Blocking.  This only generates one blocking run.  I was wondering if I'm just missing a way to do something similar but have multiple runs auto generate and I could specify the spacing?  From what I can tell, it seems Chief only knows about flat girts on the outside of the posts.
^^What I can get currently with auto framing^^
^^What I'd like to get with auto framing^^
