Show wall intersections properly
gdesignbuild
  Good morning!
  I am working on set of plans for an addition that have a split entry and trying to troubleshoot some wall issues. The single storey section sits directly on the 60" concrete foundation wall, and the storey-and-a-half section has a wood framed upper part using the 60" concrete wall as a pony wall (This section has a full basement under it).
  The blue wall that separates these sections seems to intersect through the foundation frost framing, creating a gap in the concrete wall and footing on exterior views. I have tried setting the exterior walls to frame-through at intersections but that doesn't seem to work.
  I also can't seem to get the separation between the foundation wall and upper wall to disappear. Typically, I can fool around with things until I get it right but this situation where different wall types/heights are meeting isn't coming around for me. If anyone has any advice or pointers, it would be much appreciated.
Carriere Addition - new.plan
Edited by gdesignbuild
Added plan file
