SEE THIS DECK BOARD? HELP ME MAKE IT DISAPPEAR
CDH7777
I had a deck built under this roof. I copied one of the deck boards and moved it to where it is seen in the attached pics. When I let go, my plan.file did not. It will not let me delete this board that is now floating in the air in my way! The first thing I did was try to grab it to delete. Well, apparently it is still tied to deck that I had build with railing under that roof (covered porch) so it grabs the whole deck not the individual deck board. Then I decided to use the undo command and it undid things I did before this happened so the undo command ignored the step I took to copy this deck board from the actual deck. Then I decided to delete the whole deck in hopes that that board would disappear. Nope, no deck now but I still get to keep the floating board! In plan view, this board does not appear but in section view or 3d view its there. I have rebuilt the foundation (I have noticed this simple step fixes lots of weird things CA does) I have saved andclosed this plan and reopened it to see if it is gone but nothing changes. Attached are two pics. of the floating board in two of my attempts to make it go away. Also is the plan.file (DENTON) that if you want to take a stab at it, fell free. I could use the help if anyone would kindly fix this for me so I can continue on with my project. I'm spending way to much time here on this issue...
DENTON.plan
