dimensions not attaching to walls or units. This end is offset
Kakapo247
I can select a start point, but when i select the finishing point, be it a wall or cabinet and click to finish the result is offset to the actual point required.  It Leaves me uncertain that it has measured correctly or not. Any help or direct to a fix would be great thanks
Hi Eric sorry bit of a beginner at this.   Dimension tool is point to point. Various applications but all have the same issues. In this case pictured i have attached to a wall and when it gets to the other side of the room to connect to the opposite wall it attaches and when you finish it shows up off set to the wall.
