LANDJDESIGNS Posted December 15, 2022 Share Posted December 15, 2022 Hey everyone, Do you know how to set a default for internal dimensions that is the true dimension, not the framework dimension? I need the measurement over the top of the plasterboard, but currently the interior dimensions only draws to the framework, under the plasterboard and I have to manually zoom in and move each side inwards a little bit to cover it. Is there any way to make this automatic? Thank you <3 Jayde Link to comment Share on other sites More sharing options...
richoffan Posted December 15, 2022 Share Posted December 15, 2022 Open dim defaults. Go to Locate Interior. Check surfaces Link to comment Share on other sites More sharing options...
LANDJDESIGNS Posted December 15, 2022 Author Share Posted December 15, 2022 You are an absolute legend thank you so much!!!! Link to comment Share on other sites More sharing options...
