pintodesign Posted March 14, 2014 Share Posted March 14, 2014 After the comments about the door & window schedules being off, I went thru mine. I have a shower door set in a railing wall (because the walls are 84 inches tall). Door shows up in the schedule, but there is no label on the floor plan. All the settings are correct, auto label etc., and the other doors are all ok. When I change the railing wall to a normal wall, presto! the label shows up. I know I can just lower the wall height in elevation and put a cap on it, but a railing wall is less work. I think the label should show up - yes? I need a vacation! Link to comment Share on other sites More sharing options...
