KnotSquare Posted October 13, 2022 Share Posted October 13, 2022 This is very strange, but I noticed that my base building height was 109-1 1/8" and not the 97-1 1/8" specified by my client. When I go to select a room, it is broken up into several pieces as can be seen in this snipping. I have searched, but can not find any like cases. I have included the project file zipped. The one I made the clipping of is from C1 Final.zip. The other compressed file is a backup I made prior to discovering that I had a room height issue and has the intended roof design on it, just 12" too high. Thanks to anyone that can assist. Mark C1 w Trusses.zip C1 Final.zip Link to comment Share on other sites More sharing options...
KnotSquare Posted October 13, 2022 Author Share Posted October 13, 2022 Thank you. I think when I was starting to lay out trusses I miss took the only invisible wall line for a truss. I do wish that Chief would change to the standards of drafting from the days of hand drafting. It is very clear. __________ . __________ <-- example of truss was a line dot line so you knew where each started and stopped. Similar with beams __________ ___ __________ Can't get AutoCAD to adopt it, but have a quick way to trick that program. Always appreciate your assistance. I was blinded by my own mistake. Mark Link to comment Share on other sites More sharing options...
