AndrewSopher Posted October 5, 2022 Share Posted October 5, 2022 Hello, I have been working on a plan and have a walkout basement that is a 2x6 wall with 5'' stone. When I create the foundation pony wall with stone or brick I cannot get the program to properly use the brick ledge function. I have even tested it out in a completely new plan and it seems that when there is a pony wall in the foundation Chief will not generate the brick ledge (in this case I want it to be 8''). I know I can auto detail cross sections and get it to look correct but on the elevations they are not (and if I lower the pony wall 8'' then it moves the whole framed wall 8'' and not just the brick ledge. Has anyone ran into this problem or have a solution? Thanks! Link to comment Share on other sites More sharing options...
AndrewSopher Posted October 5, 2022 Author Share Posted October 5, 2022 38 minutes ago, solver said: You have a pony wall that is brick above and concrete below, and you want to show a brick ledge in the concrete? Yes, that is correct. The brick ledge does not generate when I use a pony wall. This is essentially what I am trying to achieve. Link to comment Share on other sites More sharing options...
