creatrix Posted May 13, 2022 Author Share Posted May 13, 2022 1 hour ago, Chopsaw said: There is still a little more to learn about vector views because it needs to be standard view to see it on the teapot and it also follows the same rules in the plan as your elevation view appears to be vector which is normal so have a look in a standard render perspective view. You can switch your elevation camera to standard view but remember to switch it back. Ok, I will look in to the elevation view, if not tonight, then Sat. Out of town tomorrow. Link to comment Share on other sites More sharing options...
creatrix Posted May 13, 2022 Author Share Posted May 13, 2022 1 hour ago, solver said: If the plan is too large to attach, use Edit Area to copy the room and paste into a new plan. That's helpful! I'll look at chopsaw's and then see where I need to go from there. Link to comment Share on other sites More sharing options...
creatrix Posted May 16, 2022 Author Share Posted May 16, 2022 You have each been so incredibly helpful in my learning process — my appreciation is boundless! One step down, unknown thousands more to go! Link to comment Share on other sites More sharing options...
