TimSchrock Posted April 27, 2022 Share Posted April 27, 2022 A client wants a tall tower of their stairs and I want to show it light up at night time like a lighthouse, but my exterior camera, night shot isn't showing interior lights. I've turned off all other light sources than the one I want, Default lighting set selected, lumens cranked up to 10k, show in both ray trace and renderings, but nothing... When I turn on the light source that is in the "Outside" room, I can see it thru the stair AND front door glass. When I turn on that light source and update the lighting, THAT light shows as "In Use" but nothing I can find turns on the added light source that is in the "Open Below" room (which is the staircase). Using X13 on Windows 10 pc with Nvidia RTX3080 Link to comment Share on other sites More sharing options...
TimSchrock Posted April 27, 2022 Author Share Posted April 27, 2022 I found it. I can't use the Automatic light set. I switched to default go what I wanted Link to comment Share on other sites More sharing options...
