Different sizes for Room Labels according to scale of drawing
APTArchitect2
Hi,
1. Click on default settings.
2. Open the Room Label dialog box.
3. Select "Use Layer for Text Style".
4. Select "Room Labels" in the Active Layer Display Options (ALDO).
5. Change the text style in each Layer Display Set you want to set differently. .
If you have already named all the rooms you can select each room label and set it up as step #3.
