camera views
visions
One quick suggestion for getting a good camera view into small rooms is to make use of the "Clip Surfaces Within" option at the bottom of the Camera Spec dialog and/or the "Hide Camera Facing Exterior Walls" - as both those can let you back the camera up farther to see more of the small space.  Sometimes I have even saved a copy of the file and removed walls or made other adjustment to get a decent camera angle.
If your question is about lighting, render styles, etc - Chief has a lot of good tutorials for that.
