Leckie Posted October 8, 2021 Share Posted October 8, 2021 Not sure if I'm missing something since new update. My toilets and cabinets are moving through walls. Had to use the control key to make this happen in the past. Is there a setting that has been changed and if so how do I find it to revert back to the old settings. Thank you kindly. Link to comment Share on other sites More sharing options...
Leckie Posted October 9, 2021 Author Share Posted October 9, 2021 Thank you Eric found the check box based on your recommendation. I guess that helps. Definitely works different than I am used to. Did they change the way this works? Sorry, just migrated from X7 to X12 about 2 weeks before X13 arrived so I am having a crazy time adjusting. How cameras work was the biggest learning curve/frustration for me. thanks again. Link to comment Share on other sites More sharing options...
Leckie Posted October 9, 2021 Author Share Posted October 9, 2021 Thank you Eric Much appreciated. Link to comment Share on other sites More sharing options...
