vegarell Posted May 28, 2021 Share Posted May 28, 2021 Hi To make the emission of a material on a light source turn off when you switch off the light, you must select the Material Default Glass (Lights). Are there any other materials that can behave like that, or is there any way to make more of this kind of default materials? I'm making a visual stage plot setup for my band, and I would like to be able to create spotlights with several colors or material types with this switchable behavior, but it seems like all lights ends up with the last setting I do for this Material Default. If any developers are reading this: Is this a feature that can be implemented in coming versions (I user CAPX12)? Link to comment Share on other sites More sharing options...
