ChiefUserLars Posted March 19, 2021 Share Posted March 19, 2021 Hi, newbie question: In my geography, it is quite common to place multiple electrical switches vertically on walls. I have no trouble setting them at different heights, so it does look great in 3d. However, this causes the 2d representation to have overlapping symbols. I can enhance the view by moving the visible labels so that they are overlapping. This helps with clarity. However, is there a way where I can move the visual electrical symbols in 2d a bit away from each other, and make an arrow or similar so that they still attach correctly to the 2d wall? I have made a very simple example in the drawing, depicting my ideal situation for 2d. When renderred in 3d, the two objects would be placed above each other with shared vertical center-line, as the two objects would be placed at different heights. Link to comment Share on other sites More sharing options...
rlackore Posted March 19, 2021 Share Posted March 19, 2021 I would use a keyed note: or a notation convention that is explained within your electrical symbol schedule: Link to comment Share on other sites More sharing options...
ChiefUserLars Posted March 19, 2021 Author Share Posted March 19, 2021 On 3/19/2021 at 2:18 PM, rlackore said: I would use a keyed note: or a notation convention that is explained within your electrical symbol schedule: Expand Thanks Robert! Problem solved Link to comment Share on other sites More sharing options...
