Sunnyfields Posted January 20, 2021 Share Posted January 20, 2021 I am trying to do a presentation plan and am using a top down orthographic view with watercolor and overlaid lines. I can't get the resolution I need exporting an image from CA so I have sent the view to Layout as a live view. We also tried it as an image. The problem is that every time I try to create a PDF two walls disappear. The view box is large enough, so I haven't cropped the view, I've had our veteran Chief guy look at it, and we're stumped. Here is the result: Here is the view in Layout: And Here is the print preview: Has this happened to anyone else? I have tried outputting this about a dozen times and the same two walls are cut off every time. I am running CA Premier X12 on a Dell with these bells and whistles. I also have Bluebeam Revu as my PDF print driver in addition to the "Export" function in CA. I have tried to print and to export with the same result . Any help would be appreciated. Link to comment Share on other sites More sharing options...
Jan_Przybylski Posted October 12, 2021 Share Posted October 12, 2021 I am having a similar issue but its not cutting off the side its cutting a portion of the foundation off. I've tried increasing the viewport size and moving it to the top of the drawing order. I am using the default Chief architect to PDF printer. Any solutions found? Thanks! Link to comment Share on other sites More sharing options...
