BenReece Posted December 2, 2020 Share Posted December 2, 2020 At a loss here! Could someone take a 3D look and tell me if you have any suggestions for either of these two things.... #1 I am trying to place a round gable roof vent on the left front main gable as seen on the right side... It will not let me center it and it also will only show the outer edge of the vent. It's like the middle area of the vent is behind something. I do have a material region over this area if that is relevant information. #2 My other issue is the second story balcony on the front of the structure. Out of the blue, I must have done something that I did not notice to cause the right side railing of this balcony to become a wall of some sort. You can see an outline of a wall here when you turn off railings, but it will not let me select it no matter what. When I move the balcony railing from it's current location it goes back to normal. Only I don't want to move it because this is where it needs to be. Thank you for any help. Mountain View Apartments Project.plan Link to comment Share on other sites More sharing options...
BenReece Posted December 7, 2020 Author Share Posted December 7, 2020 These were all extremely helpful!! Thank you so much for taking the time to go through that. I appreciate it! Link to comment Share on other sites More sharing options...
