contearchitect
Drywall return on cut wall
Please post images (screen capture) directly -- no need to make a PDF of an image. This makes it easier for others as an image shows in the forum.
And please check your messages.
Probably how your wall is defined.
Look at how I defined the wall in this plan that corresponds to your problem wall. I've reversed the layers compared to the other walls -- brick is on the interior, drywall on exterior.
Move your brick to the exterior layer from the main layer to experiment and see what wraps on the end of the wall.
bw.zip
Just now, contearchitect said:
Thank you!
Happy to help.
You can help all of us by completing your signature.
    28852
    CPDesigns
    CPDesigns
