stevenyhof Posted October 6, 2020 Share Posted October 6, 2020 I have run into this a few times and can't seem to get rid of it. I do not want the boxed fascia on the gable end. I want what is on the left, not on the right. I even deleted the right roof and copied the left to the right - it just comes back. Thoughts? Thank you! SND1854 Potter Barn.plan Link to comment Share on other sites More sharing options...
stevenyhof Posted October 6, 2020 Author Share Posted October 6, 2020 1 minute ago, solver said: Those are really buggy and seem to eventually get correct. If you pull the porch roof back several feet, the main roof will fix itself. And why do you have a p-solid here? Thank you - I did not think the other roof would do this, but I will remember that. Link to comment Share on other sites More sharing options...
stevenyhof Posted October 6, 2020 Author Share Posted October 6, 2020 1 minute ago, solver said: Make that wall a Pony Wall I use pony walls for my foundation and some brick/stone walls on the main floor, but did not know I could use them in the attic. I will make it happen! Thank you Link to comment Share on other sites More sharing options...
stevenyhof Posted October 6, 2020 Author Share Posted October 6, 2020 Actually in this case, the attic wall split at the trim board so just changed the material. I've done some strange things with gable materials so was just not thinking - that was much faster. But I will mess with pony walls also. Link to comment Share on other sites More sharing options...
stevenyhof Posted October 6, 2020 Author Share Posted October 6, 2020 4 minutes ago, solver said: The split was just a little below, I think. Material regions are also better than p-solids as they replace the materials. I deleted and redrew the porch roof and changed the wall polyline for the wall the roof butts into. 310642828_SND1854PotterBarn (eric).zip Thank you Sir! Link to comment Share on other sites More sharing options...
