TCDLLC Posted July 30, 2020 Share Posted July 30, 2020 I created a box bay window and know how to adjust a window component - size, frame, sill, etc. But how do you replace the window type with a window from the library? I have a fixed window component and want to replace it with a manufacturer's window with muntins. But when I tab to the window component, I cannot select the option to replace it with an item from the library. Any suggestions? Link to comment Share on other sites More sharing options...
TCDLLC Posted July 30, 2020 Author Share Posted July 30, 2020 I found the parameters I needed and it worked. Thanks so much! Link to comment Share on other sites More sharing options...
