PMMully Posted July 10, 2020 Share Posted July 10, 2020 Can CA to be able to specify horizontal layers as well as vertical layers. Am I missing something? Meaning, having a tie-beam as part fo the mix. I was sent this great article by support on how to add a tiebeam into a standard CBS wall. https://www.chiefarchitect.com/support/article/KB-00495/creating-walls-with-a-block-and-tie-beam-cbs.html That is fine, it's great. But, if it looks like there is only one Pony wall default, and that will change with each build do to height. Any other ideas on how to capture this detail? Link to comment Share on other sites More sharing options...
PMMully Posted July 10, 2020 Author Share Posted July 10, 2020 24 minutes ago, solver said: Wall types may be stored in the library. Create several that represent common wall heights. Or, add short wall sections to your template plan. Click one to select, click the Set As Default tool and your pony wall defaults are set to the specs chosen. That will work. I started with HD Pro about 10 days ago, and move to CA-P this week. Love the tooling. I will add this to my setup process. Link to comment Share on other sites More sharing options...
