OneChickNoHammer Posted June 25, 2020 Share Posted June 25, 2020 Another short video on how to keep curtains open when stretching a rod across a wide window or door. It was suggested to use a stretch plane, which is a quick and easy way to accomplish this task. However, the method I showed using 2 separate curtain symbols allows for more control on how wide to make the panel. This can be crucial if the walls to the side of your door/window are narrow. Link to comment Share on other sites More sharing options...
OneChickNoHammer Posted June 25, 2020 Author Share Posted June 25, 2020 Thank you Eric, I was wondering if that method would work. And you've proved that it does. Lisa Link to comment Share on other sites More sharing options...
