Wall Covering Pattern and Texture Questions
ajworkman93
Hello, my name is Aaron
I am having some design issues while using Home Designer Pro 2020 and I am seeking some help.
While drawing a full bathroom I am having trouble getting correct finishes to render in 3D.
I have a flooring material snipped from a google search that I wish to use as a 24x12 tile on the floor in a 1/2 offset grid but while it shows the pattern in orthographic view it does not in the standard doll house view.
What steps am I not correctly taking or settings that may be off that are not rendering the finish properly? (see attached photos for reference)
Also I am having an issue with a wall covering that shows the covering extending past the desired area of the wall.  I have a tub surround area for tile to be installed and on the plumbing fixture wall I have increased the thickness by 1/32 to make sure that the wall tile material is only in the tub surround.  While it works for my 20x8 it does not work for my 12x4 subway.
What inputs have I not correctly executed that now shows the subway extending past the desired area? (see attached photos for reference)
I appreciate all and any help on these issues.
Aaron
