Rails offset: how to manage on stairs & balconies
CV-reno
I have a balcony I need to reproduce where the railings (platform & stairs) need to be centered on the posts supporting the roof.  See attached.  I can offset the newels, but the railing won't follow.  I can shift the railings but the balcony and stairs will shrink/expand (BTW, what's the use of offsetting newels?).  I've looked at all the options, but dead end.
I know I can 'fudge' this by 'constructing objects' to get the result, but should I need to do this?  Simple solution?
X12 9 Kay-2 front balcony.pdf
Hi Eric,
Signature updated.  The PDF was not meant to be, was aiming for the image of, but screwed up.  BTW, thanks for always being here; do you ever sleep?
Not sure I understand your suggestion.  Increasing the 'wall width' will not shift the railing on the stairway or balcony base, which is what I'm after; and BTW, how to you get to that DBX for a staircase?.  I may have missed the essence of your message, it is late, sorry.
