Gable Roof at Front Won't Center
KnotSquare
The gable roof I placed at the front of the home will not center within the room so that I can design architectural trusses accurately within. I drew a CAD line down the center, and if you zoom in, you will see that the ridge of the roof planes do not quite match up.
I added interior walls between the Kitchen and Great Room just to verify that it was not the invisible wall causing this issue. I can't seem to solve the problem.
Any suggestions?
Thank you,
Mark
20.02.19 Arch'l Trusses 1.zip
