ASH_UK Posted February 11, 2020 Share Posted February 11, 2020 Issue 1 - I want to build a Clerestory Roof. I've tried to follow the guide at KB-00492 but it messes up the roof. Ideally want the higher roof above the lounge so a high window can be placed lighting the balcony. Issue 2 - the shelf ceiling above the lounge, is not a room per se. So I can not add, for example, a glass railing or open up the ceiling above the stairs. Any ideas? Issue 3 - how would I create a wall similar to the picture attached around the property boundary? Only need the panel inserts around drive with the full height wall going around the sides and back. The side walls will create a hallway and enclosed path down the sides. I want to learn how to do this rather than have the changes. Realistic_Build.plan Link to comment Share on other sites More sharing options...
Signatures Posted February 11, 2020 Share Posted February 11, 2020 Welcome It's helpful to know what software you are using as it changes from version to version. It helps others to have this info in your signature so it's always available. Please see this topic for a signature how to. https://chieftalk.chiefarchitect.com/topic/18908-signature-here-at-chief-talk 1 Link to comment Share on other sites More sharing options...
