Sign in to follow this
kevin30
Autocad Import: Multileader not working
Hi,
I understand a new feature in chief 11 is importing autocad files and still keeping the mulitleader text function as used in autocad. I tried and the arrow and text import fine but the leader line does not. Also, I was assuming if it imported correctly the text, arrow, and leader line should all be connected as if you used the same tool in chief. I have quite a bit of details to transfer over and it would be pain to have to adjust every single leader line. Any help would be appreciated.
    28433
    SD_JDanW
    SD_JDanW
