cpridemore Posted August 30, 2019 Share Posted August 30, 2019 Is there a way to change all the pulls on cabinet doors & drawers at once? Right now I change them individually. Link to comment Share on other sites More sharing options...
Chris_Kelly Posted September 5, 2019 Share Posted September 5, 2019 ^what Eric said. But also there is a tool called object painter. I'm not sure if you can use it with hardware, but it can be used in most cases where you need to change the properties of multiple things. It's a godsend when changing cabinet moldings for example. Link to comment Share on other sites More sharing options...
