Hi all any suggestions on how to adjust cabinet to angled wall.
see image..
note this cabinet will only be half functional from front on but the back will be chamfered to suit the wall.
I have tried to look thru the options but nothing seems to address my requirements.
thanks in advance
Have shown this on the forum in the past-use an angle front cabinet and rotate it. Then you can still change the door style, a symbol won't let you do that.
Once you have the angle correct and fit into place you can drag the end opposite the angle, the back in the one shown, along the wall to change the width.
Angle cabinet.plan
