Auto-Roof ignoring Wall pitch specs
Rashid_Garuba
This worked fine over the weekend,, As Porch wall pitch is changed the Roof autobuilds with new pitches.. Now it doesn't respond to any wall pitch changes.. The walls are set to 8:12 but the Roof builds to 12:12 every time, ignoring the wall Roof Specs.. The red lines are what we should have.. etc. I come back to Chief after a long hiatus and I have to learn to program again.  Probably some default setting, but I haven't changed anything there..
Thanks..!
5935 Olde Atlanta Pkwy 8_12.plan
16 minutes ago, solver said:
Like this?
And a suggestion. You have the default pitch set to 10, then you are overriding it to either 8 or 12 in the walls.
Instead set the default to whatever most of the roof planes use, then override in only the walls where the roof plane is different.
Good advice... went manual to finish..
