Design, Construction Documents & Renderings Help Available now!
Flach2
I Just wanted to introduce myself.
I’ve been in the building business for 25 plus years, mainly remodeling, (some new homes).
Cabinet maker, finish carpenter, remodeler among other things. (I know how things go together!)
Can communicate with Architects, builders & remodelers well.
Have been certified in & using Chief since version 6.
Have been working remotely all over the country for many years.
I work fast & reasonably, usually from a matter of days to 2 weeks turn around time.
Please see my work here: www.theprojectdesigners.com
Plan examples & references available on request.
Thank You for Considering me,
Tom Flachbart from The Project Designers
603 770 6078
tom@theprojectdesigners.com1356046982_Untitled20.thumb.jpg.b15220957393c37c700df2110050b5b4.jpg
Example_Plans.pdf
  • 1 month later...
Dear Tom,
I am a new user of Home Designer Pro but need assistance to get to a completed plan.  I am rebuilding a 1970s Ranch by basically demolishing the original house and rebuilding on the foundation with some new additions included.  The floor plan is basically completed and my wife will go through and choose the interior designs. My current problem is the roof and truss design. We want to add a large cupola or upper clear stories ceiling/roof. I have a sketch that might help you understand what I need.
In the end this is a pretty simple design but the idea is to give the house a modern and unique look by altering the curbside appearance, and creating a high central ceiling with lots of light coming in from the back (south) into the kitchen/living areas.
Can you help design the roof as described? Provide engineering knowledge? Create a plan complete enough to submit for a permit in Idaho?  How do you charge? What is your availability?
Roof Scetch 1. 7-11-19 07112019.pdf
    30405
    ElzaBDesign
    ElzaBDesign
  • Similar Content
    • By fletcher
      I'm having issues with my walls not returning over a lower roof plane on a raised section of my home. When I try to extend the walls it shows up on my floorplan inside with brick which is not accurate.
      Does anyone know how to fix this?
    • By davebrett
      I am very new to Home Design Suite Pro and could use some help. I have looked for video's but all don't quite get me there.
      I am trying to build a free standing peaked roof pergola.
      I would like it 10' x 10 ' square with 8" posts and a 12" support post under the peak of the roof (so not very sloped).  I have attached a picture of what I am trying to make.
      I have tried making railings, walls and slabs, but I keep missing something.
      Help please
    • By decorators3
      Hi
      I see some fabulous renderings on CA facebook..  Are these designs created with CA and then rendered outside CA site.??  My renderings are not bad but some of the ones I see look so realistic.. I'm wondering where they are rendered   If these samples I see are done thru  CA ' rendering feature then I definitely need more practice and instruction.  If there are other sources can anyone tell me the best ones to look into..
      Many Thanks
      CA x 11
    • By Designer_Maddee
      I have been trying to create more photorealistic renderings with Chief as I don't have the current budget for additional software.
      I have been playing with the CPU Ray Trace option and keep coming up with grainy images that seem darker than I'd like.
      I have played with the lighting and sunlight and I've pushed the resolution higher and higher every time I try with no luck.
      If adjust the contrast of the image it makes it a little brighter, but it still is lacking.
      The first image went for 60 passes, the next one was 40 and the 3rd was 50 passes.
      I would love some insight and recommendations on fixing the grainy look as well as just creating more realistic images!
      Thank you!
      I am using Premier X13 on iMac
    • By raltd9245
      i'm drawing a demo plan and want to show demo doors as dotted w dotted swing. I can't figure out how. Any ideas
