Randino Posted May 15, 2019 Share Posted May 15, 2019 Cannot find walls for the room to which the back of the dormer should connect Chief Architect Premier X10 Build 20.3.0.54x64 Professional Design & Drafting Software May 31, 2018 Got a story and a half, Roof ignores 2nd floor and raise/lower From Ceiling height 10" Added dormers to front and back. When I add railing around stairs and then open to below I get: Cannot find walls for the room to which the back of the dormer should connect Everything is fine until I created the "open below" and then I loose the dormers. What am I doing wrong. Drawing attached Dormers.plan Link to comment Share on other sites More sharing options...
Randino Posted May 15, 2019 Author Share Posted May 15, 2019 That worked! but why? I exploded the dormer and all appears find. I did get a warning message that If I turn on auto rebuild roof changes will be lost. Thanks for the quick replay Link to comment Share on other sites More sharing options...
