ChiefUserJarmo
How to fix wall connections in off-angle corner walls to enable resizing the door
Here's the issue I have - I have this weird corner case of walls with multiple angles. As shown in the image, the underlying CAD has a door and I just cannot resize the exterior door properly. I think it is because the walls on left and right just kind of run into the diagonal wall and block the resizing of the door. I tried editing wall intersections but that did not help. The side walls just snap back. Any ideas how to solve the issue? Right now CA allows me add a door with 339mm width, but I need 700mm width.
You should attach your plan file with this type of question.
Try drawing Room Divider walls where the red lines are. The other walls will (may) butt into them and not overlap.
Finally got it working (in a way) with room dividers and changing the wall thickness. Not 100% accurate - but good enough.
Thanks again Eric, for pointing to right direction!
695727698_Screenshot2019-03-07at22_11_09.thumb.png.0974d897fe682af28c92e8ae6c0e37ce.png
and I found another workaround - create the perimeter with thin walls first, add doors and then convert the wall type to thick wall.
    27865
    RichRidgewood
    RichRidgewood
