Dave13 Posted November 21, 2018 Share Posted November 21, 2018 I'm trying to get rid of the lighting hot spots on the ceiling. I've changed the 2 x 4 lighting from standard library 2 x 4 light lighting white material to emissive and shut the lights off for ray-trace. The light showing in the ray-trace are added lights with spot light setting @ 25w. I've tried parallels, point and spot lights all with the same result. The ceiling is a GWB, painted with with a poly-line solid t-grid. I'm trying to just evenly light the store without lighting hot spots. Thank you for any advise you can provide. Version 8x Link to comment Share on other sites More sharing options...
