BFogarty Posted November 14, 2018 Share Posted November 14, 2018 Wondering why the white strip carries around the window? If I change the material to match, it turns the outside of the sash to an undesired finish. I can post the plan if needed, but I figure the picture will do the trick. Thanks! Link to comment Share on other sites More sharing options...
BFogarty Posted November 14, 2018 Author Share Posted November 14, 2018 2 hours ago, solver said: Because that's the way the program works. It's been complained about before. So there's no fix? Other than wrapping each window with a p-solid and matching materials, which is ridiculous. Link to comment Share on other sites More sharing options...
BFogarty Posted November 14, 2018 Author Share Posted November 14, 2018 Thank you! Link to comment Share on other sites More sharing options...
