Lee66cj5 Posted January 22, 2018 Share Posted January 22, 2018 I have a stair with open treads on one side for the first 5 1/2 treads then a solid wall hiding the rest of the treads. Under the stairs I have a partial laundry room that has a 2x6 wall instead of the 2x4 wall that encloses the rest of the stair. I have 2 issues getting the stair to function correctly. the first issue is the 2x6 wall should be cut by the stair and the wall above the stair should become a 2x4 wall (we us a diagonal top plate at the bottom of the stringer height and build 2x4s above). The second issue is if I add a partial height wall below the stair then the side wall cuts below the stringer and makes an open tread stair above which I do not want. Does anyone have any ideas to fix these two issues? Thanks, Lee Marwick.plan Link to comment Share on other sites More sharing options...
Lee66cj5 Posted January 22, 2018 Author Share Posted January 22, 2018 Thank you! this fixed the problems. Link to comment Share on other sites More sharing options...
