Sign in to follow this
40mstew
barrel roof into sloped roof
I'm trying to put a barrel roof entry into a sloped roof. See pic. I want the barrel to start from the garage fascia and go to the front door. I have it partially done, but was wondering how to close the 2/12 roof down onto or "join" the 2/12 pitch roof to the barrel roof. If I start to break lines and modify roof planes my self manually, sometimes I get a fascia board on the inside of the barrel ceiling. I tried the "join roof plans" tool and I get some funky roof concoction. I attached plan also.
X9
Stewart_2018_1-19-18_copy.plan.zip
I do curved roofs as a single plane, not 2. Set the pitch to 0 and adjust the angle/radius.
Shape the porch roof like this, then select the far end of the curved roof and join it with the roof just above. It won't be perfect -- you will need to fiddle with things to get a clean fascia.
I don't know of any other way of making a barrel roof except for joining 2 roof plans and setting ridge to 0 degrees. If I try to do a flat roof to a barrel it gives me a single sided 1/2 barrel.
Delete one of the barrel roof planes. Drag the edge of the remaining one across to make 1 wider roof plane.
Set pitch to 0, add curve.
    27468
    gbattaglia
    gbattaglia
  • Similar Content
    • By 9atatimer
      I'm using X11 premier on a mac -- I have an exterior garage wall (with a centered garage door) and a gable end -- I'd like to split the attic wall of the gable end into 3 parts -- the central region above the garage door, and the left and right, to have a different material above the garage door.
      I have Default Settings > Roof > Auto Rebuild Roof set to Off
      I have Default Settings > Framing > Automatically Build Floor and Ceiling Framing Off on all framing types.
      I have Default Settings > Walls > General Walls > Auto Rebuild Attic Walls set to Off
      If I delete the roof and ceiling planes with Build > Roof > Delete [X] and then use the Build > Roof > Build Roof ... dialog to rebuild the roof and attic from scratch -- I leave the Auto Rebuild Roofs set to Off, to be clear -- and then edit the resulting gable roof on the attic layer, I can split it twice to produce the three separate wall sections, but once I change the exterior material on any of the sections, the three wall segments get replaced with a single wall again.  The new wall has my selected material, but that does me no good as I need the distinct secgments.
      Anyone know what setting do I need to turn off to maintain the manually edited gable end?  Or is this a mac bug?
      Or, barring that, does anyone know what approach will let me give the desired finish detail (attached a pic of a freehand elevation)?
    • By blueriver
      I'm using Chief Architect Premier X11
      I have all these little 'X's can someone please tell me how to get rid of them?  I've been really playing around with the roof and i THINK they are from that but at the same time i have a couple random ones outside where the roof is -- i cannot get them to go away. Help!
      thanks in advance
      Lauren
    • By chief69
      Hello, We are having a hard time getting  the design program to do the roof right. We have tried with Sketchup and it got the closest. It's hard to describe I have attached a few pics with a decent idea of what we are trying to do.
      The Garage is a shed roof as well as the breeze way, but they are at different angles. The house is a butterfly style with the V running at a angle. WE do not care what the pitch ends up being on any of the roofs.
      Anyone know how to do this. I have been trying for hours and the program goes crazy every time. Esp with the all 3 roofs at different angles with each other. I have attached a copy of the plan we made and some pics from sketchup because that program got the closest to what we are trying to do.
      Thanks
      Chris
      New house v1.plan
    • By MN_JohnH
      I wonder why my second floor loft flooring is sticking through the roof and can be seen on the outside of the building?
