Sign in to follow this
ARBergman
Terrain Pad Problem
Hi Chiefs,
Making this cantilevered room but the terrain pad is still showing. I created the first floor, then the terrain, and then the foundation in that order. Then  I modified the automatically generated foundation to cantilever the room above, but then this hole showed up. I tried to make a new terrain , but the hole remains. What can I do to remedy this situation? Why do you think this problem is happening?
Thank you for you help!
q1.plan
Uncheck Hide Terrain Intersected by Building and draw your own terrain hole. Select the exterior room. Create a Room Polyline. Convert the polyline to a Terrain Feature, check Make Hole.
    27483
    Reboreb
    Reboreb
