Suggestions Posted September 13, 2017 Share Posted September 13, 2017 I just learned about a feature that has probably been in the program for quite some time... thought I would share, in case others weren't aware. Did you know you can enter Pitch Values into the Allowed Angles dialog instead of needing to specify degrees? Simply type the value in this format: "4 in 12" Chief will convert to degrees for you. 1 Link to comment Share on other sites More sharing options...
