emtjim Posted August 27, 2017 Share Posted August 27, 2017 Ok, I have a design I did and want to do a walkthrough. I don't want the basic walkthrough so I laid out the path using the spline tool, which I converted to a WT. Here is my issue; its a two story home and I can't get the WT to continue on the second story. The only information I can find says to stop the WT at the steps and it will continue on the next level.... Do I start a new spline on the next level and the two auto connect? Will the WT spline on the first floor auto extend to the second level?? Any help would be greatly appreciated, Jim Link to comment Share on other sites More sharing options...
Chiefer Posted August 27, 2017 Share Posted August 27, 2017 You can assign Frame X to Floor 2. No need to start a new spline. Link to comment Share on other sites More sharing options...
emtjim Posted August 28, 2017 Author Share Posted August 28, 2017 I'll give it a shot. Thank you so much! Link to comment Share on other sites More sharing options...
