Richard_Morrison Posted August 23, 2017 Share Posted August 23, 2017 If you have a good start on your remodeling plans, but really want to make your home "sing," I can help you get there. If you are unsure about the design direction after playing around with it for quite awhile, and need help getting your remodeling designed and built, I can help you get there. I am a licensed architect and interior designer with over 30 years of experience, and have dealt with most of the planning departments around here for many years. San Francisco Bay Area only. It will be a good fit if you understand your needs quite well, but recognize your design limitations and abilities, and are open to new ideas. I listen carefully, and probably will suggest alternate solutions that you may not have considered. It probably will NOT be a good fit if you "know exactly what you want," and just need someone to draw up the plans for permits. I also have design coaching services, if you only want some excellent design advice. www.richardmorrison.com Link to comment Share on other sites More sharing options...
