Sign in to follow this
CUBRAD
X9 ROOF AND WINDOW PROBLEMS
The roof on the backed worked right the first time I place it but the clients wanted to see roof hipped. Now I can't get it back to gable. Also they want then windows to be 3'x5' mulled fixed on bottom floor and up above they want them 3'x5' mulled double hung.  My problem is when I put window in the upper floor it changes my window below from fixed to hung windows. Please help.
Untitled_1.zip
What do you want gabled?
What windows are you referring to?
Well I deleted them upstairs in the front of the house. I need to 3x5 mulled together for a 6'x5' DH Single unit but when i put them in it puts bar in the center of the window below. It changes them from fixed to a hung window.
You attached the wrong plan.
I copied the lower window to the 2nd floor, then changed each window to single hung. Click the window, tab to select it, open and change.
Break the back wall as shown, set to full gable.
Why is there a fascia board showing above that gable now?
I'm confident you can figure that one out.
well it wasn't there in my first drawing. Thank you four the help! I just tried to open my file back open and got this...
    27494
    theCADStudio
    theCADStudio
