DaViper Posted March 29, 2017 Share Posted March 29, 2017 I have a large building and generated 3 walls that adjoin to one of the exterior walls. Since I did not have to create the 4th wall (exterior wall), I guess chief won't look at it as a separate room. No biggy really but walls are 6" lower than the 0" floor plane. I open the detail page for each wall but cannot find a way to fix this issue. The detail page shows the wall floor height (C) as 0" so I am confused here. Do I need to add a polyline to connect this space as 4 walls? What is an easy work around? I just need to lift all walls up 6" Update: Just as a test I created a stand alone wall and it was correct. So I went and deleted one of the 3 walls and it generated fine. Then I deleted another and it worked but the one I previously changed went back to 6" low. I think there is something going on when it ties into the exterior wall. ? I notice that now my exterior wall bottoms are at -6". What I did was delete my base slab which was 6" thick. I think the walls then dropped. That seems to be the issue but not sure how to fix it. Link to comment Share on other sites More sharing options...
DaViper Posted March 30, 2017 Author Share Posted March 30, 2017 Got it. Apparently in Room specifications I had it toggle for a 6" floor so I guess the exterior walls were generating to cover that. I changed that to 0 and all is well. Sorry for the bother. Link to comment Share on other sites More sharing options...
