Bi Level Entry & Siding not lining up
Designedit
Hi
I have been adjusting and fiddling with this plan for hours. I need the side entry to be at ground level with stairs to the main and basement. The front of the home has a full foundation bay window. I can't get siding to appear where the chief vapor barrier is showing or the foundation to line up with the second floor. Any suggestions?
Open the foundation wall dbx and on the Wall Types section, make it a pony wall with siding on top and the concrete wall on the bottom.  Then you can adjust the height of the concrete wall accordingly.
Hope that helps.
